rim and tire question
Old Mar 27, 2003 | 08:38 AM
red94z28's Avatar
the stock camaro wheel is 16x8, im pretty sure. would a 15x8 fit in there or what.
Old Mar 27, 2003 | 08:52 AM
AlexBarabas's Avatar
Of course, as long as it had the same bolt pattern.
Haven't you ever seen people bling blinging with bigger rims? Same applies to smaller ones -- but seriously, they look sort of weird. I think 17-18 is the best looking on these cars.
EDIT: And make sure to get tires for the 15" rims that would add up to equal the stock diameter, or else you've just changed your gear ratio.
Stock diameter of wheel + tire combined = keep it the same!
Old Mar 27, 2003 | 08:58 AM
red94z28's Avatar
alright then, i dont think there is no way for that 15x8 rim to fit into my stock tires is there.
Old Mar 27, 2003 | 09:02 AM
LWillmann's Avatar
No, the stock tires will not fit on those 15x8 wheels because the tire is for a larger wheel.
Also, you have to watch out for brake clearance issues. I have heard of people having to grind the calipers to clear some 15 inch wheels.
Just be careful!
Old Mar 27, 2003 | 09:04 AM
red94z28's Avatar
the rims, if i get any would be the cheap ar767, basically the black nomad wheel, i wonder if grinding would be needed on these
BandDirector Blk98ZM6
Feb 20, 2015 07:42 AM
Kato
Jan 26, 2015 09:21 PM
Jason Short
Jan 19, 2015 06:33 PM
Hurin
Dec 13, 2014 07:38 PM
siguy
Nov 27, 2014 10:07 AM
