Car Won't Turn Over...
Old Mar 27, 2003 | 03:17 PM
csabatka1's Avatar
Turn the key and it doesn't do ****. Doesn't even sound like the selenoid wants to kick it. I know its probably some wiring, but does anyone have an idea of which wires to look for.
I did have a hose split open on me and spill a bunch of antifreeze all over the place, but I've started it the day after (Tuesday) that happened just fine, I went out there yesterday and it didn't start up.
All the gauges work, battery tests at 12.3x volts, about 95% charge, and about 600 cranking amps, so the battery is fine.
Old Mar 27, 2003 | 03:31 PM
94F1Z28's Avatar
After you try starting it and then turn the key to the off position does the security light stay on.If so it is the VATS system,wait 3-4 minutes for the light to go out and try it again and you will have to get it fixed or bypass it somehow.I have this problem right now and sometimes it takes as many as 6 tries to get it started which is 3min for every try so i am getting the VATS system programmed out of the computer by pcmforless.
Old Mar 27, 2003 | 03:42 PM
AlexBarabas's Avatar
throw it in a lake and get insurance $ off of it.
Edit... I'm kidding... bet insurance people are watching.
Old Mar 27, 2003 | 03:49 PM
94F1Z28's Avatar
I hope they are not watching,if they find out what we are all doing to our cars we will all be paying extremely high insurance premiums
Old Mar 27, 2003 | 04:20 PM
csabatka1's Avatar
Security light does not come on or does not stay on...
Old Mar 27, 2003 | 04:31 PM
z28Power's Avatar
Turn the key to the on position without trying to turn the engine over. Do you hear the whine of the fuel pump coming on?
Old Mar 27, 2003 | 04:34 PM
csabatka1's Avatar
yeah, it comes on. It would still crank if fuel pump was out.
Anything that could of possible been hurt in the area of the battery by that antifreeze?
Old Mar 27, 2003 | 04:56 PM
z28Power's Avatar
Well if you spilled antifreeze on the opti, that would definitely cause problems :-) Would be a bad thing though.
Old Mar 27, 2003 | 05:05 PM
csabatka1's Avatar
well, the car would still crank over, if it was opti...
Old Mar 27, 2003 | 05:18 PM
Perhaps your clutch start switch. Yellow and brown wired connector on the clutch pedal. You can pull it off and bypass it with a paper clip for testing purposes.
Old Apr 14, 2003 | 02:53 PM
z28house's Avatar
Z won't start
I had the same problem this morning and couldn't start my Z. Just cleaned coolant level sensor yesterday to get rid of low coolant sensor light. In the process some coolant spilled because I didn't train any out. I had battery out of car. Put battery back in and started car fine and drove back in garage. This morning turned key to start and doesn't even crank. No security light because I disabled VATS with a resistor about a month ago and battey seems to have power to run everything. I hear fuel pump kick on. Wondering if it is starter or clutch switch? Anyone have a pic of clutch switch location? Would starter go bad just like that? Ever figure out why yours wouldn't start???
Old Apr 14, 2003 | 08:43 PM
csabatka1's Avatar
mine ended up being the starter itself. It had a bad spot in it. I hit it with a hammer a couple times and then it cranked over. I replaced it with a new one from OReilly Auto Parts (I work there and get awesome discounts) and now I have no problems.
Old Apr 15, 2003 | 07:31 AM
z28house's Avatar
Also banged on mine a few times and it started so I replaced it with a new starter from Advance auto parts for 150.99.
Old Oct 5, 2003 | 03:31 PM
ThotYouKnew's Avatar
where is the starter located?...i think my problem is the clutch switch possibly....
I have a 96 camaro z28 M6
i put the clutch in and turned the key and the lights in the dash lit up and my radio turned on but you couldnt hear a click, it wasnt trying to turn over....and so i took the key out and tried it again...same thing...i sat there for liek 2 mins and put it in and it fired up....
later on, i tried starting it after gettin home from a football game....this time i cranked it like 10 times and nothin...and then i start jammin the clutch in and turnin the key at the same time and i could hear it try to turn over...and finally after about 10 tries it started up...also i must have blown the cd player fuse, because it wouldnt turn on....
any ideas? getting fuel pressure, brand new battery maybe a month old, the old one was leakin acid...with the old leaky battery, in the cold, the car wouldnt start, you could hear it clickin but it wouuld never start until it was jumped...also, the low coolant light came on last sunday...but hasn't returned....
jj71787
Dec 30, 2014 02:15 PM
Cam's maro
Dec 28, 2014 09:30 AM
CARiD
Dec 26, 2014 04:20 AM
USAirman93
Nov 24, 2014 03:37 PM
NAVY99
Oct 3, 2002 03:47 PM
