View Full Version : LT1 Based Engine Tech
- Car Acting Up
- Size of the serpentine belt?
- Pro-Billet Distributor- Or just cap and rotor?
- canton oil pan leaks help!!!!
- Alternator power
- very unique opti problem...bad oscillations destroying bearings? help!
- Hey all, I'm back. Going to try this again...get the 383 running.
- does anyone have a diagraham of the metal lines that bolt to the back of the heads ??
- size of oil dipstick bracket bolt
- performance when hot outside
- Start up issue
- Oil Preferences?
- Need a little help
- 2 ac problems
- I broke the starter solenoid wire
- exhaust cut-out
- Car trouble, need advice!
- dynomax catback, what are your thoughts?
- Cars stalls at stops, idles bad...intermittent problem...HELP!
- any write ups on installing AC compressor?
- Fluid spewing out of the dipstick tube
- OiRemoving timing cover without messing up oil pan
- Question about Aeromotive Fuel Pump Controllers please...
- long tube headers
- Actual cat-back gains?
- O2 sensor voltage difference??
- Strange problem with 1995 LT1, I think its the tune?
- Stainless header bolts in aluminium heads
- Car runs fine until it warms up then goes crazy.....help.
- MSD Pro Billet LT1 Distributor (Opti)?
- miss/pop at top of third on my "new" lt1
- what wires?
- Post pics of your LTCC setup
- m6 torque arm bracket part #
- Car is dead AGAIN: fusible link by the starter??
- Coolant Tube that connects to back of the heads
- Cam suggestions??
- Will the dynomax bullet muffler help my motor?
- 1997 ss intake
- 383 guys: I NEED HELP!!
- Need a picture of a slotted TPS.
- 267,000 miles and finally let go...some pics inside!
- Compression Test
- llyod elliot product forum... please post!
- EWP fuse?
- Arghhh!!!
- Code P1441 Evaporative Emission (EVAP) System Flow During Non-Purge
- 94 octane
- Higher than normal idle and surging of rpms
- Free mods
- got my MOJO back!!!! plus cc306?
- LT1 headers
- Poslished intake ...is it possible?
- cam shaft
- Is this normal?
- weird start up!
- Le2 383 Stumble Issue *update*
- I got an oil leak this car wont gimme a break!
- Optispark...what is it!!!!
- high idle part 4...injuneer, help!
- hp builder
- Will I benefit from a 2 1/2 y pipe with high flow cats?
- Major car problems please help
- i dont know why im asking this but.... next mods
- knocking and pinging at low temps after rebuild?
- i havent changed my air filters in 2+ years.
- Having problem with 94Z LT-1
- Radiator suggestions
- Got Granatelli's and pics?
- Im bleeding the coolant and.....
- gas in the oil?
- lower fuel pressure cause low rpm surging?
- Deltech Ltcc dyno numbers
- question about Z that sputters then dies
- help with car having no power after turning off
- Engine Click
- Aftermarket LT1 Crank Part #'s
- Used cam?
- ? about fuel injector electrical connectors...
- got to thinking....
- Can 3 miles do this much damage?
- Intake gasket
- 95 lt-1
- OEM lifters
- How many sensors?
- Best place to buy 50lb injectors
- MadZ28 Tune for 96Z????
- Stock radiator or aftermarket?
- My serpentine belt shredded itself- :(
- !Cats + Loudmouth = PO400
- Has anyone ever put older 350 in a 4 gen camaro???
- max lift in a stock valve cover
- I need a fast answer (24hours) come in plz
- Oile Level Sensor resistor size needed
- Why is oil slowly draining off the spark plug?
- Setup questions
- Fuel Pressure Drop - Why?
- power programmer
- low coolant light
- cleaning the MAF and TB
- Hypertech III dyno tuning?
- More good Lloyd Elliott results
- installation cost for motor mounts
- Could a knock sensor trouble code cause transmission issues?
- Blew it up !! What to do? 355 vs; 383 vs; 396
- Why a DTC 33? Some advice....?
- coil
- SES Message Question
- Trouble code 61. Help me out guys
- Need part number......
- Aftermarket Air Intake for LT1
- IAT relocation after a speed density conversion
- power steering probs? plz advise!
- Fuel line repair/replacement?
- Will this work for my LT1????
- FS: (for sale content deleted)
- what else?
- motor mounts...separate shells
- 93 firebird formula with lt1 wont start
- rattling vibration
- morel lifters
- my project, oh boy this is great
- Lifters don't bleed down? Valves stay open?
- Help with dtc's!
- Intake gasket or main seal??
- What Parts Should I Get
- Waterpump gasket leaks
- Bad Vibration!!!!
- Need Help Removing Pass Header
- Blown head gaskets!!
- Can aftermarket wires be too well shielded to use a timing light gun?
- new TB NEED SOME HELP!!
- new setup???'s PLEASE HELP
- Just when my car is running GREAT, this happens, now it won't start.
- Need Quick Help...
- Should I get heads/cam or just do bolt-on's?
- Lt4 Hc Hp?
- GM 847 cam on 114 LSA?
- Broken Valve Spring - Symptoms?
- Scan readings - any help??
- LT1 Fans problem
- Oil Pan Gasket Question?
- Ignition switch, Ignition cylinder, or what else?
- Car is missing at idle and under load, at random
- my car's idle is wacked!! Any ideas appreciated
- Damn comp lifters...what I found...
- OBDII / LT1 coolant Fan(s) operations
- EVAP & EGR info?
- Easiest way to chang out lifters?
- Here we go again :^(
- Lt1 Oil Leak Back Of Intake? Help
- I'm having troubles with running issues...
- Hypertech vs Madz28/PCM4LESS ???
- LT1 engine block
- Collector Gasket and Bolts...
- what lifters with Hot cam kit?
- LE3 lifter question
- engine problems
- I Know I Know....
- Random cylinder misfire - what now?
- Wanting to hook up Faze Air Fuel gauge, which wire on the o2 sensor do i connect to?
- Stumbles very very bad, o2 or MAF?
- True duals
- best wires for lt1 w/hooker LTs and what igniton box
- Car drinking gas, have no idea, but have a CSV file
- injectors
- Anyone make a 1 5/8 primary long tube header for lt1
- Will these headers fit in my car?
- Here's a good one that might not have been ask yet!!!
- spun bearing? (large pictures)
- 383 is now running
- P0336 code
- help header install
- new dyno graphs from my 218/224-112 CC502!
- o2 sensors, same for front and rear right?!
- HUGE MYSTERY!!: blown ignition module and 2 starters (Shoebox + other experts within)
- How many gaskets?? Please read
- 02 simulators
- Elite Wires Thumbs Down
- help is my engine done?
- Kooks and true duals are in! Pics!
- 1.5 to 1.65 Roller Rockers?
- TFS head: Tiny oil return holes. Issue?
- I Would gain any HP ??? (Roller Rockers)
- Need Help Custom Cam vs Off the shelf
- fuel pump question
- problems with idle
- Does anybody have a LTCC on 96-97 F-Body????
- Valve spring retainers, locks and shims part # question...
- Valve adjustment question from a non-newbie.
- Quickest 60' possible w/ T56 and 10-bolt?
- Failed emmissions...barely. What can I do?
- water pump leak
- Rings for stock pistons
- Few Questions: OTVC Setup With Accel Wires
- 355 Rebuild
- Cleaning the MAF for amatuers
- Contacting Joe O.
- y-pipe catalytic converter question
- Tranny Fluid leak - pissed
- high idle problem... part III new discovery)
- How do you use a self tuner?
- Paxton SN-2000 HELP
- Emissions! Myths or truth
- Question about Crankshaft pulley
- Code 32 (EGR fault)
- Maximum safe C.R. LT1 on pump gas
- More trouble in Aftermarket Optispark Land
- Vibration -> SES light
- Improved TB Bypass Q-> Removing hoses too?
- Strange Missfire
- How the heck (pretty big tune up LOL)
- question about afpr..help
- TB bypass leaking!!!
- Odd Miss
- RPO codes
- best place to buy CC305 kit
- Holley 52mm throttle body
- Are all gen. II LT1 camshafts ?????
- Question about 50# LS1 injectors on LT1.
- Cam questions
- Pro Action Heads
- Uggg, always something (carnage pic)
- slp headers
- weird problem come inside!
- Ignition fuse has blown 3 times!!!
- i need to buy a WP.help
- Injector problems?
- Valve locks
- why does it idle so rough?
- what 2 use 2 keep oil from getting sucked into the intake port via rocker stud hole?
- new throttle body from summit?
- How is opti-spark driven ???
- Where to find LT1 timing chain ???
- crazy oil pressure
- Hose from FPR to where?
- Need help, I need to know the two wires for the reverse lock out on my AUTo to 6speed
- 355 or 383???
- Intake Manifold Porting
- reasonably priced full LT1 gasket set ?
- po100
- Header bolt hole stripped out
- found custom cam need help
- tested coolant temp sensor with DVM
- Just went from bad to disaterious!!
- How can you tell which piston is missing??
- map sensor dtc 34 "revisited".......
- help 1.6 roller rockers stupid question
- what would cause car to crap out in closed loop w/ new O2's?
- Helllzzzz Yeeeaaahhh!!!!
