canton oil pan leaks help!!!!
Old Jun 19, 2006 | 08:01 PM
Black6spdZ's Avatar
I just go tmy motor done and i cant get the pan to quit leaking from the drain plug. i tried the copper gasget and a different rubber gasket and they both leak a lot when the oil is warm. Has anyone else had this problem or what can i do to fix it?
Scott
Old Jun 19, 2006 | 09:43 PM
firebirdStud's Avatar
Re: canton oil pan leaks help!!!!
check above the oil drain plug. on top of the passenger kick out there is a plug that leaks like a siv, and runs down the pan. Do a search, there was a recent post about it.
HectorM52
Jul 30, 2017 11:46 AM
DirtyDaveW
Mar 15, 2015 07:01 PM
TAChad
Jun 14, 2002 03:44 PM
