help with car having no power after turning off
Old Jun 17, 2006 | 04:25 PM
easyc4's Avatar
so i just plugged my battery abck in after ahving it out for a month and it would crank, but wouldn't fire, so i had to jump it. started right up all was good. then i turned te car off and tried to immediatley turn it back on and nothing, no lights, no bells or whistles, nothing. so i jumped it again, turn off, same thing. triewd it one last time to move it for the night, jumped it and turned it off and wwhen i went to turn it back on, it cranked, but wouldn't start then i tried again and it started. what do u guys think? loose wire somewhere? or am i looking at a alternator going bad? btw my battery is not even 2 years old.
Old Jun 17, 2006 | 04:44 PM
DarksideII's Avatar
Re: help with car having no power after turning off
I had this problem. My red power wire going to the starter was corroded all th way through the cable, not sure how this happens, but i replaced and it started fine.
Old Jun 17, 2006 | 04:49 PM
Eddie95Z28's Avatar
You never said how long you would let the car run for after you jumped it? Just letting the car idle for a few minutes isn't really enough to get the battery going again. But aside from that it could be the alternator. Or the wiring. I would check the little red box on the passenger side wheel well corosion there can cause all kinds of problems.
Old Jun 18, 2006 | 11:05 AM
easyc4's Avatar
i hope its just the wire, i'll check today, maybe the contact bolt got a little rusty in the winter time. i would ussually let the car run for about 10 minutes or more, letting it get to running temps, etc. also i drove it down the road and back a few times on the second try when it just had no power wat-so-ever on startup
liamcg97
Nov 25, 2019 05:55 PM
Injuneer
Dec 15, 2014 09:36 AM
CaRParts102
Dec 6, 2014 08:45 AM
USAirman93
Nov 24, 2014 03:37 PM
Dave19yz28
Jan 26, 2003 01:45 PM
