Car trouble, need advice!
Old Jun 19, 2006 | 04:32 PM
thegift's Avatar
I have a '94 pontiac firebird trans am, i was driving on the freeway when she started to lose power and slow down, and she eventually cut off. I've had no problems with her until today, I think the problem might be the igition module, but Im not sure, looking for any suggestions as to what it might be.
Old Jun 20, 2006 | 05:19 AM
Guest47904's Avatar
Guest
Re: Car trouble, need advice!
Start easy and then work toward the complicated. Start by relieving any fuel pressure at the schrader valve. Cycle power 6 or 7 times to on for 3 seconds and then off without cranking the engine. Then check the schrader valve again to see if pressure built up.
If that appears to be ok, check a few plugs for spark.
If that's ok, check the injectors for pulses.
Scan for codes.
Old Jun 20, 2006 | 07:19 AM
Sweetred95ta's Avatar
The motor only needs 3 things to run. Air, fuel, and spark. Find the one it doesn't have or isn't working properly and you may have your answer.
1775.Z28
Jan 11, 2015 10:51 AM
ModdedNerd
Dec 10, 2014 08:42 PM
tds1213
Nov 27, 2014 12:55 PM
USAirman93
Nov 24, 2014 03:37 PM
supercharged94Z28
Feb 24, 2003 10:22 PM
