SES Message Question
Old Jun 16, 2006 | 08:22 AM
dirtybird222's Avatar
Ok the other day at work I plugged in the OBDII diagnostic tool to check and see if I had any other codes being thrown besides my EGR one because of my headers. I got a new one that I haven't seen yet it was a "Random/Multiple Cylinder Misfire code" someone I work with who is pretty knowledgable about cars tells me it's most likely my opti getting ready to go. Tells me to throw it in fifth and step on it to see if the car struggles at all. It doesn't, so what could this code being thrown be for?
Old Jun 16, 2006 | 10:07 AM
Re: SES Message Question
The crank position sensor is seeing irregularities in the crankshaft speed that match the profiles stored in the PCM to indicate misfires. Virtually any item can contribute to this problem.... spark, fuel, mechanical problems, CKP sensor problems, rough roads, etc. I wouldn't jump to the conclusion that its the Opti.
Old Jun 16, 2006 | 03:43 PM
Sgt. Spuds's Avatar
Yea, have them clear the codes and then go back in a few days to see if it happend again
Old Jun 16, 2006 | 03:58 PM
moparman's Avatar
I'm assuming it's the P0300 code. As Injuneer said, don't jump to the conclusion it is the opti. It could be plugs,wires, coil, etc. When it's dark, raise the hood, start the engine and see if there are any obvious misfires.
Old Jun 16, 2006 | 06:34 PM
yes it is the P0300 code, I believe it came back again today, but it could just be the EGR, I'll check again tommorow at work. And tonight for misfires, which I dont think is it. Any other way to figure this out?
Old Jun 16, 2006 | 06:47 PM
moparman's Avatar
P0300 is not a code for the EGR. It can become nerve wracking trying to chase the random misfire down. I chased it for a couple of months. Finally the scan tool told me the cylinder, and it was a burned wire. Couldn't see it from the top, and it didn't always miss unless it was raining or high humidity.
Old Jun 16, 2006 | 07:57 PM
no i was saying that i didnt know if it was the egr code coming back up or the misfire code! and oh god, well lets see I'm in florida so it is either raining or having 100% humidity!
Old Jun 16, 2006 | 09:07 PM
moparman's Avatar
An enhanced OBDII scan tool might pin point the cylinder.
Old Jun 17, 2006 | 12:43 AM
looks like i might have to take a trip to a dealer or one of the craptacular tuners around here in cent. fl No one I know has one. One other question, I've been told there is an opti-conversion where you can buy a new opti and hook up LS1 style coil packs and you aren't really using the opti except for the signal and the coil packs are supplying the spark! What is this system and where could I find it if it exists? Sorry for the ignorance!
ChrisFrez
Dec 21, 2014 09:47 PM
ChrisFrez
Dec 15, 2014 03:09 PM
ChrisFrez
Dec 7, 2014 06:01 PM
ChrisFrez
Nov 23, 2014 10:33 AM
sfGi8nt
Aug 1, 2002 05:54 AM
