Broken Valve Spring - Symptoms?
I am of the belief that I may have a broken valve spring. In the absence of popping the valve covers, what are the key symptoms?
I am experiencing a definite misfire on at least one cylinder. Rough, lumpy running at all RPMs.
Re: Broken Valve Spring - Symptoms?
If you have stock valve springs the valve would have dropped, go into the cylinder, and most likely create some damage (you would know). If they are not stock I don't really know.
