My serpentine belt shredded itself- :(
Old Jun 16, 2006 | 10:37 PM
indirocz28's Avatar
was drivin around tonight... and then all of a sudden my serpentine belt just shredded itself.- it was dark so i couldnt tell how bad the damage was but i know that i saw one wire that had the covering torn off of it,- i hope it didnt hurt my new MSD plug wires.. it also took the connector off the A/C compressor... there is rubber stuffed behind the tensioner pulley, and more rubber behind the AC compressor..
How good are the chances that it ****ed up somethin good??.. My "check Gauges" light came on also...
Old Jun 17, 2006 | 01:23 AM
Ray86IROC's Avatar
Re: My serpentine belt shredded itself- :(
Mine shredded itself as well, the alternator was cracked and the pulley grenaded, power steering pulley was dented (I was able to unbend it well enough), and something in the A/C compressor was damaged enough to spring a leak. I don't know if the belt did all that damage or the alternator tore itself up and took out the belt too, either way my junk was majorly hosed...
Hopefully yours will not be so bad, good luck.
Old Jun 17, 2006 | 01:48 AM
popo8's Avatar
I was driving one day, and I srarted hearing a noise like I drove over fresh tat kicking up rocks... next thing I knew, car shut off... turned out the tensioner took a dump
Old Jun 17, 2006 | 05:00 AM
2000GTP's Avatar
Thats what I was thinking, it may be something as simple as the belt tensioner failed. On one of my previous cars, when the belt tensioner broke, the serpentine belt was chewed to pieces.
Old Jun 17, 2006 | 05:21 AM
6SpdLT1Z's Avatar
due to the lack of power when you lost your altenator.
I'm bettin it's just the tensioner because mine went out about 3mos ago. Shreaded the belt and it snapped on me, lost power steering, check gauges came on, etc.
Old Jun 17, 2006 | 06:56 AM
indirocz28's Avatar
Ok.. Thanks guys!- i was going to replace the tensioner anyway because there is so much rubber packed behind it....
Jeff
95blkss
Sep 22, 2015 03:18 PM
rideordie
Sep 7, 2015 08:22 AM
john henry
Aug 14, 2015 08:33 AM
john henry
Classic Engine Tech
88IROC_Z
Jul 22, 2015 11:38 PM
