Stainless header bolts in aluminium heads
I bought some ARP stainless bolts for my LT1 heads. I've recently heard, however, that stainless doesn't work well with aluminium, that it may corrode either the bolt or the head.
Comments?
Comments?
Re: Stainless header bolts in aluminium heads
Dissimilar metal corrosion can occur any time two different types of metal make contact with the help of a little moisture. Stainless is probably better than, not worse than, other types of metals. Your fasteners have to be made out of something! So I'll take stainless over standard steel any day. Just make sure you use the anti-seize like "redta" said.
i just got some afr 210 alum heads and went with some arp stainless header bolts.im afraid if you put antisieze on them they could eventually back out and may need to be tightened often which is a bitch if you have long tubes.
i just put some low strenght loc tite on them
