o2 sensors, same for front and rear right?!
I have two bad and decided to buy all 4 replacements since I will be under there. The two fronts are the same as the two rear right? I just buy 4 of the same sensors?! This is on a 96 z , thanks ---
Re: o2 sensors, same for front and rear right?!
If I splice everything together the actual sensor is the same right? There is some AC DELCO ones on Ebay and they say "work for front and rear" , comes with wire splice kit.....or should I just do it right and buy harnessed ones? Thanks ---
Splicing isn't the best way to treat an O2 sensor. They use stainless steel wires. The sensor output is in millivolts..... a small bit of corrosion or a sloppy splice and your whole system is fubar.
jj_burchiel
Mar 21, 2015 12:51 AM
Dec 4, 2014 11:56 AM
