LE3 lifter question
Old Jun 14, 2006 | 11:10 PM
Black6spdZ's Avatar
LE3 lifter question
Will the new stock lifters work or do i have to get something else? If i need something else what works best?
Thanks Scott
Old Jun 14, 2006 | 11:12 PM
30AnvZ28's Avatar
Re: LE3 lifter question
I was advised against using stock replacement... as I would shatter them. I used Morel drop in style lifters.
Old Jun 14, 2006 | 11:14 PM
Black6spdZ's Avatar
thanks for the quick reply, where did you buy them from? I didnt think about this until today when i went to put stock ones in the car. Is anyone running stock lifters with a le3 package?
scott
Old Jun 14, 2006 | 11:26 PM
30AnvZ28's Avatar
I bought them from Victory Racing. They are expensive as ****... but for the sleep I gained at night on them... it was worth it.
Old Jun 14, 2006 | 11:42 PM
396D1SS's Avatar
i was using comp type R's but they suck and fell apart. i am using new oem ones right now and they are working just fine
Old Jun 15, 2006 | 02:33 PM
cmroSS97's Avatar
Comp OEM replacements here too
Old Jun 15, 2006 | 02:44 PM
redemn93's Avatar
javier97z28 is using comp oem's in his le3 setup. doing just fine. we run the **** outa that car to.
Old Jun 15, 2006 | 05:55 PM
1racerdude's Avatar
Your stock ones will be fine if they are checked and in good shape. The way ya bust them is not enough spring pressure,
Old Jun 15, 2006 | 06:09 PM
NightTrain66's Avatar
Are they some LE3 heads that are already done and you are buying from someone else, some that I did for you or some that you are needing me to do?
I use the 26918 beehives for customers with stock or replacement lifters.
Customers using R lifters or Morel lifters can get the 26120 beehives for the same price.
I have also used some of the PSI springs (160 lbs on seat and 420 lbs open) for customers needing something like that. This set up will cost more and is not used very often since you need Morel lifters, GOOD pushrods, rockers, etc.
Old Jun 15, 2006 | 06:19 PM
30AnvZ28's Avatar
Thats the route I went.
HectorM52
Jul 30, 2017 11:46 AM
oldschool
Feb 9, 2016 09:21 PM
jj_burchiel
Mar 5, 2015 07:05 AM
Red_94Formula
Jan 22, 2015 12:17 AM
donot_4get
Sep 14, 2002 08:03 AM
