Question about 50# LS1 injectors on LT1.
Old Jun 13, 2006 | 12:01 AM
Mike96z's Avatar
I found some 50# injectors from an LS1 for a great price, think they are Delphi or something like that.
Now the question, the guy said they would be less than 50# on my LT1 due to lower fuel pressure? Is that true and if they run at a lesser rate, what would it be???? Thanks for the input.
Old Jun 13, 2006 | 12:10 AM
Re: Question about 50# LS1 injectors on LT1.
The LS1 injectors are flow rated at 58psi. At the stock LT1 pressure of 43.5psi, they would flow 43.3 #/HR. Are you sure they are high impedance injectors?
Old Jun 13, 2006 | 12:15 AM
Mike96z's Avatar
Are you talking about stock LS1 injectors? These are delphi 50#, so don't know if that's factory or High Performance? And are the stock ones high impedance? Not sure but I'm running stock 24# LT1 injectors tuned to 26# so they have to be way better than mine. I have a 388.
Old Jun 13, 2006 | 09:40 AM
Sweetred95ta's Avatar
The stock injectors are high impedence, and you need to make sure the 50#'s are high impedence also. Injuneer is saying that when LS1 injectors are rated, they do it with a fuel pressure of 58 psi. The LT1 injectors are rated with the fuel pressure at 43.5 psi. You need to know what these injectors are rated at, at different fuel pressures. They will flow less on an LT1 if the fuel pressure's are kept stock.
rideordie
Nov 5, 2019 04:52 PM
Sergio
Jan 27, 2016 04:27 PM
jayblev95
Track Kill Stories
Jan 15, 2015 07:48 AM
ChrisFrez
Nov 23, 2014 10:33 AM
