problems with idle
Old Jun 13, 2006 | 10:35 PM
97 LT1formula's Avatar
problems with idle
For some reason my car doesnt like to idle right at times. Sometimes it will idle at 650-700rpm and stay there the rest of the drive till i shut the car off, when i start it again itll idle around 900-1100 and be very rough. Car is 97 formula, 79k miles with pacesetter LT's, ORY, CAI with brand new OTVC wires and ngk tr55 plugs with roughly 4k miles on them. Any ideas on things to check would be greatly appreciated.
Old Jun 13, 2006 | 11:53 PM
blackztpi's Avatar
Re: problems with idle
does the car seem a little down on power? check your vaccum. could be a vaccum leak?
Old Jun 14, 2006 | 12:02 AM
not down on power at all. my elbow was ripped so i thought that was it but replaced it with a 1LE elbow but didnt seem to fix it. all vacuum lines are good.
When i put the car in neutral itll jump to almost 1300rpm
Old Jun 14, 2006 | 07:28 AM
Sweetred95ta's Avatar
Check your IAC counts. You need a scanner to do this though. A scanner can tell you what your vacuum is doing also. You should create a signature so that we have a general idea of what is done to your car. For example, the valves may need adjusted, but I don't know if you have any mods at all, besides what you've listed.
lt1matt
Mar 21, 2015 07:35 PM
edman
Mar 13, 2015 09:39 PM
Magenta_Hearts
Mar 5, 2015 07:01 AM
edman
Jan 25, 2015 02:41 PM
slothgrant
Aug 22, 2002 03:01 PM
