355 Rebuild
355 Rebuild
I was wondering about how much forged rebuild to a 355 would cost. any help is appreciated. Im taking into consideration that the head work and cam (probably LE2) will cost. Any ideas of how much the boring will cost and what other parts will i need? probably some dumb questions but im kinda new to building engines and trying to aquire as much knowledge as i can. thanks.
Re: 355 Rebuild
A 383 won't cost any more than a 355. Both being forged 4340.
Ya will probably have a $1000.00 machine shop bill.
About $2000.00+in the complete kit including rings and brgs.
$2500.00 in a good set of heads.
$7-800.00 in a valve train with cam.
$800.00/$1000.00 in gaskets, timing set,and accessories.
If ya are not doing the work of pulling it and building it yourself, ya are looking at another $2000.00.
Might want to look at a rebuilt short block from one of the board sponsors or Golen or a GM stroker crate engine.
Re: 355 Rebuild
LE2 package+rr,lifters,pushrods-$2300
Eagle rotating assembly-$1800
Block machine- $1000+
Gaskets- $400
Clyodes true roller-$100
Time spent building your own motor Priceless $$$
+All the extra stuff I didn't mention that drains your wallet.
Gaskets- $400
Re: 355 Rebuild
VRE 355LT1 Economy Shortblock-$2999.99 NO Core Charge
-Eagle 3.480” stroke Cast Crankshaft, Eagle H-Beam Connecting Rods, SRP Pistons, Perfect Circle Rings, Clevite Main Bearings, Clevite Rod Bearings , Clevite Cam Bearings, ARP Main Studs
VRE 355LT1 Racer Shortblock-$3290.00 NO Core Charge
-Eagle 3.480” stroke 4340 Crankshaft, Eagle H-Beam Connecting Rods, SRP Pistons, Perfect Circle Rings, Clevite Main Bearings, Clevite Rod Bearings, Clevite Cam Bearings, ARP Main Studs
