reasonably priced full LT1 gasket set ?
Old Jun 12, 2006 | 06:30 PM
EnerjetF67's Avatar
I'm looking for a reasonably priced NAME BRAND (full gasket set for my LT1 383 build.
So far I have found sets for $365.00, $298.00, and $201.00.
I DO NOT find those prices even CLOSE to reasonable, LT1 or not.
The shop that sold me my rotating assembly supposedly can no longer get this set, therefore they refunded me a measley $100.00 to find my own gasket set...what a freakin' JOKE !
The shop that sold/balanced my rotating assembly jerked me around for over a month....I originally wanted a forged 355 assembly and after several excuses about back ordered pistons, cranks, unavailable pistons, etc.....for some reason the OWNER of the shop that sold me the package took 3 weeks to tell me they could not do the package I wanted for an internally balanced LT1....I wound up with a 383 instead.....PM me and I'll tell you who to avoid........the package was supposed to ship out in less than a week. It took me over a month to get 90% of my parts & I was almost ready to give up & call my attorney.
I'll (nor will 3+ of my buddies with LT1's ready to build) NEVER use those liars again.
Old Jun 12, 2006 | 06:50 PM
96arcticwhite's Avatar
Re: reasonably priced full LT1 gasket set ?
Fel-Pro PN's CS9966, HS9966PT should be around $230 for both from Summit/Jeg's/a parts store. Or just get a tube of ultra copper silicone and "get creative"
Old Jun 12, 2006 | 06:53 PM
EnerjetF67's Avatar
That seems RIDICULOUSLY high......an LT1 is only a freakin' 350 chevy with a FEW added special gaskets.....one can get a NAME BRAND SBC 350 gasket set for under $60.00 easy. Can I use one of those and add the special pan & front gaskets ?
Old Jun 12, 2006 | 07:08 PM
Kevin Blown 95 TA's Avatar
head gaskets are $33x2 Intakes are $17x2 Oil pan $28 water pump and timing cover kit was $15 or so rear seal not cheap, egr gaskets a few bucks, header gaskets $30-$40 or so for good ones, those washers at the back of the heads expensive at the dealer, valve cover gaskets $17 or so
It all adds up rather quick, but modern gaskets are damn good compared to what you got for $28 for a cardboard & cork set with plain metal shim head gaskets in the old days. Heck, I just spent $140 just for a pair of head gaskets and $40 for header gaskets and $10 for some can of Right stuff and you know MY LT1 DOESN"T LEAK AT ALL !!!!!
Old Jun 12, 2006 | 07:22 PM
EnerjetF67's Avatar
Looks like $201.00 from Summit it is.....
Old Jun 12, 2006 | 11:22 PM
seawolf06's Avatar
http://thunderracing.com/catalog/?ac...vid=4&pcid=157
I'd spend the extra couple bucks and get all GM gaskets.
oldschool
Feb 9, 2016 09:21 PM
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
Queens94z28
Dec 20, 2014 09:11 PM
Brandon Wittmer
Dec 8, 2014 07:53 PM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
