Need Help Removing Pass Header
Re: Need Help Removing Pass Header
Originally Posted by mooner
I have a cracked long tube header on the passanger side of my 94 Firebird (LT1) and need help on how to remove it so I can fix it.
Originally Posted by 2000GTP
It should then come out the top with a little patience.
Originally Posted by Spitfire557
There's no way it's coming out the top. Get it in the air and take it out from the bottom.
Just an idea.....
Would it be possible to repair, maybe weld while still installed on the car? This would be my route (if it's possible). Like maybe even unbolt them for movement, but not remove them for the repair.
I would not want to install/remove headers any more than absolutely needed.
drptop70ss
May 4, 2015 08:22 PM
squarehead
Nov 21, 2014 08:02 PM
