map sensor dtc 34 "revisited".......
Old Jun 12, 2006 | 03:22 PM
93black-ta's Avatar
heres my old thread.
http://web.camaross.com/forums/showthread.php?t=439755
The same problem is still occuring.
the car will not run/idle for more than a second or so.
engine running (throttle proped a little open to keep it that way) i got around 2v. B to A ive got 4.8v. Does this tell me my sensor/wiring are deffinately o.k.?
valves are properly adjusted
map sensor/pigtail have been replaced with no change.
IAC passages were cleaned
how can i figure this out without scan tools? im pretty tired of throwing money at this car without results.are there any other sensors that might confuse the MAP's readings?maybe a bad throttle body?
KYWes
Jun 14, 2022 06:52 AM
Aug 24, 2015 06:41 AM
350350
14
Aug 11, 2015 12:03 PM
whitehooptie
Aug 10, 2015 07:02 AM
Aug 7, 2015 01:26 PM
