Is this normal?
Old Jun 18, 2006 | 01:13 AM
NYC32798's Avatar
Question Is this normal?
I decided to clean the throttle body off today and do the coolant bypass mod at the same time while I had it off. I put a rag underneath the first coolant hose before I pulled it off. I pulled it off and.... no coolant. So I got around to the second hose, pulled it off, and again no coolant. I checked the coolant level to make sure it was ok and it was. The car was running about 30 minutes before I pulled the hoses and there wasn't even a trace of coolant in the hoses or throttle body. Is it only supposed to go through the lines when it's running? Or could there be a clog somewhere I need to worry about? I highly doubt it should be completely dry like it was with no trace of coolant.
Old Jun 18, 2006 | 04:59 AM
kingman109's Avatar
Re: Is this normal?
hmmm.... mine pissed a small amount when i did mine- if car had been running for 30 min id say should have been at least something...
how long did the car sit after it was run before u did it?
Old Jun 18, 2006 | 08:52 AM
RichardZ SS's Avatar
Re: Is this normal?
I did mine yesterday also. I seriously doubt if there was a tablespoon TOTAL of coolant spilled. Im sure my system needs a good flush, but it hasnt been running hot or anything so I dont think Ive got any issues there. The way it looks to me, coolant wont even flow thru the TB until the whole system reaches normal operating temps and the thermostat opens and sends the coolant thru the engine. That coolant hose comes off the very top of the radiator and until the system builds some pressure, there wont be anything going into it. Just my .02, but Im not too worried about it.
Old Jun 18, 2006 | 10:19 AM
NYC32798's Avatar
Re: Is this normal?
It sat for about another half hour. I'm just worried cause I don't know if theres something blocked up or if theres crap floating around in the system I need to worry about.
Old Jun 18, 2006 | 10:37 AM
shock6906's Avatar
Re: Is this normal?
When I did my TB bypass it seemed like coolant steadily leaked from the input side until I capped the line off. I'd say there definitely should be fluid running though there, or at least a hint that it has recently.
PopoFormula
Oct 12, 2015 04:19 PM
WobblySausage
Oct 7, 2015 10:09 AM
Hal Fisher
Sep 30, 2015 09:03 PM
SEOJustin
Sep 24, 2015 04:39 PM
plattted
9
Sep 20, 2015 11:23 AM
