Collector Gasket and Bolts...
For Hooker Long Tubes, What collector gasket and bolts are you using? I'm thinking about going with the Flow Tech set up from Summit part # BIG-10025FLT, seems like it comes with bolts, will this work?
Neil
Neil
Re: Collector Gasket and Bolts...
never use the gaskets that come with the kit unless you want to install new ones within 1000 miles after they blow out. unless they are quality aluminum ones or atleast a mr gasket or felpro will last awhile
WobblySausage
Oct 7, 2015 02:44 PM
