my car's idle is wacked!! Any ideas appreciated
Old Jun 15, 2006 | 10:04 AM
jbh2317's Avatar
Hi, 95Z M6 here having some idle issues. When the car is just idling it jumps up and down in rpm pretty erraticly. Runs fine driving it just idles poorly. About 300 miles ago rebuilt the top half of the engine from blown headgasket. replaced water pump, opti, coil, plugs, wires, cap and rotor, o2 sensors, and had the heads resurfaced. All I can imagine is the IAC valve or valves not being adjusted properly??? Please help!
Old Jun 15, 2006 | 10:31 AM
jbh2317's Avatar
Re: my car's idle is wacked!! Any ideas appreciated
sorry I didn't include this in original post. Car is also running pretty rich. Only mods to car are k&n, Long tubes and true duals. Thanks
Old Jun 15, 2006 | 10:34 AM
Sweetred95ta's Avatar
Do you have the means to check your IAC counts? You can clean these also. Try that and re-adjust your valves. Do you know what your MAP sensor is reading?
Old Jun 15, 2006 | 11:32 AM
1quickTA's Avatar
Also check your vacuum lines for any tears or anything you forgot to connect.
Old Jun 15, 2006 | 12:37 PM
jbh2317's Avatar
don't have the means to check iac counts. I will check my vacuum hoses hopefully this evening. Any idea how much a new iac costs and best place to get one?
Old Jun 15, 2006 | 02:13 PM
Try and clean it first. If it breaks, no biggie because you're buying a new one anyways. Do you know anyone with a throttle body you could throw on your car? That at least would narrow it down. It only takes 5 min to pull the tb off.
Old Jun 15, 2006 | 02:25 PM
Why do you feel its running rich? Under what conditions.... idle?..... part load/closed loop?..... WOT/PE mode?..... "all of the above"?
Old Jun 15, 2006 | 10:49 PM
jbh2317's Avatar
Whenever I crank the car and rev it up the black smoke stains the concrete under the exhaust pipe. also, just idling there is a moderate amount of gas smell. Exhuast pops some too, don't know if that's just because or if it is related to this.
Old Jun 16, 2006 | 07:53 AM
I think that you almost have to hook it up to a scanner and read the sensors to find the problem. Do you have a labtop? There is freeware on the internet that would allow you to scan your car. You'd just need a cable. AKM sells them. I bought mine for like $45 from Mastach.com .
Old Jun 16, 2006 | 09:22 AM
hawk29's Avatar
hey sweetred95ta what software are you using to scan? Freescan looks like it only supports 94 and older so what else is out there? And is there a cable to connect to the 95 OBD1 connection since it is the OBD2 style but OBD1?
Old Jun 16, 2006 | 09:35 AM
Your 95 OBD-I PCM is identical to the 94 PCM.... FreeScan will work. So will TTS DataMaster which is also free for a limited number of uses. You just need the correct cable, because your 95 has an OBD-II ALDL connector under the dash.
DataMaster:
http://www.ttspowersystems.com/diagnostic.htm
Cables:
http://www.akmcables.com/
There's also a version of EFILive (V4) for OBD-I:
http://store.efilive.com/
Old Jun 16, 2006 | 01:07 PM
Mastach.com has the cable with prongs on the end, so you can use it on the obd1 plug and the obd2 plug. I've had mine for a while now and never had any problems with it. Plus, it's cheaper than the other "molded" plugs. Freescan does work on a 95 and PCMComm also works and is free.
Old Jun 16, 2006 | 05:19 PM
dangalla's Avatar
i would take some carb cleaner and check around the intake manifold and tb for vacuum leaks, sounds like the culprit to me.
Old Jun 16, 2006 | 08:59 PM
jbh2317's Avatar
sounds like a plan, will have to check that manifold..
Britbilly
Jan 7, 2015 08:49 PM
ro2207
Dec 4, 2014 06:18 PM
USAirman93
Nov 24, 2014 03:37 PM
Lions3
Apr 11, 2003 10:55 AM
NAVY99
Oct 3, 2002 03:47 PM
