Injector problems?
Old Jun 12, 2006 | 10:38 PM
monte385's Avatar
Injector problems?
This is for a friend with a 94 Z we just did a rebuild with a mild cam & Edelbrock headers. The cam is 218 @ .05 in. & ex. on 112 las.
It runs OK but it has a miss at idle on #5 & #8 bring it up off idle & it's OK.
He had the injectors cleaned at a GM dealer prior to putting it togther.
He was going to bring it to the dealer & have them scan it & see what they find.
Second ? are the stock injectors going to deliver enough fuel with the above mods or should he step up to a bigger set or maybe just an adjustable fuel press. reg.?
Thanks Jim
Old Jun 12, 2006 | 10:57 PM
Re: Injector problems?
The stock 24# injectors will be adequate over 400 flywheel HP. He isn't there yet. No need for an AFPR.
Old Jun 13, 2006 | 10:27 AM
monte385's Avatar
Thanks, what about the misfire @ idle, like I said the injectors were just cleaned.
Maybe the cleaning loosened up enough crud to cause problems?
I'm an old school carb guy I'm not too educated on FI.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Alex Barnes
Jan 24, 2015 10:21 PM
nophix
Nov 30, 2014 10:26 PM
