size of oil dipstick bracket bolt
I am having a headache trying to tighten up my oil dipstick. There is a bracket on there that you cant get to easily from the top. The last time I changed out my plugs, I worked it a little loose. I tried from the top to tighten the bolt, but no luck. What size is the bolt 3/8 ???? Where is the best place to get to it so you can tighten it...from the bottom I imagine....The GM engineers need there as* kicked for designing the passenger side engine bay on these car.
Re: size of oil dipstick bracket bolt
>remember that most if not all fasteners on these cars are metric not SAE (yes there are some sizes that are the same like 10mm and 3/8",13mm and 1/2", etc.)
Originally Posted by shoebox
Actually, anything that bolts to the block on an LT1 is not metric. 10mm and 3/8, 13mm and 1/2 are not close enough to be called the same in my book. I would never interchange tools for those as you could strip the heads.
ChrisFrez
Jan 11, 2015 03:47 PM
Darth Xed
13
Jul 22, 2002 12:45 PM
