Wanting to hook up Faze Air Fuel gauge, which wire on the o2 sensor do i connect to?
Allright- ive got a 94 z28 m6- and i installed a Faze a/f ratio gauge today- and i am not getting any reading's..- what wire on the driver side o2 sensor do i need to tap into for a reading??
Re: Wanting to hook up Faze Air Fuel gauge, which wire on the o2 sensor do i connect to?
Originally Posted by 396D1SS
It has been along time since I hooked this guage up but I believe it was the purple wire.
You hook up to the harness wiring, anywhere between the PCM and the O2 sensor plug. Do not cut into the O2 sensor wires.
Drivers side is purple/white wire on PCM pin C20. Passenger side is purple wire on pin C8.
Some people run both sides to a single-pole/double-throw switch, so you can select either sensor to be displayed on the gauge.
When you get all done, its not going to show you much, except maybe if you have a complete sensor failure. The O2 millivolts switch too rapidly in closed loop, swinging from very lean to very rich. At WOT they will be more stable, but the stock narrow-band sensors aren't accurate at the A/F ratios used for WOT.
Garcia5
07-07-2022 06:51 PM
07-04-2005 05:00 PM
