Coolant Tube that connects to back of the heads
Old Jun 18, 2006 | 09:45 PM
Heatmaker's Avatar
Advanced Member
Is this the correct part # for the Tube that runs down along the passenger side of intake manifold and connects to the rear of the heads? I had to cut mine off in order to remove the cylinder heads... kept stripping the bolt out.
12556260
THanks-
Old Jun 18, 2006 | 10:34 PM
Re: Coolant Tube that connects to back of the heads
That is correct for the pipe, bolts and seals for 95-97.
Old Jun 19, 2006 | 01:58 AM
1racerdude's Avatar
Don't know if ya want to go to the trouble but I put JIC fittings in the heads and run a hose with a junction in the middle so if ya ever have to take off one head ya can take the hose loose after removing the intake.
I use a wire braided hose with JIC reusable fittings for the hose between the heads and go to the rad with a regular hose with a crimped swivel fitting on the head end and the clamp at the rad.
calaban
May 18, 2020 06:43 PM
HectorM52
Jul 30, 2017 11:46 AM
94Z28LS1toLT1
Jan 15, 2015 07:18 PM
thenewkid
Nov 18, 2014 12:57 PM
Jul 4, 2005 05:00 PM
