Ignition switch, Ignition cylinder, or what else?
Old Jun 15, 2006 | 11:19 AM
fast96lt4's Avatar
I got off at a video store and i only took about 5min. I get back into my car and it won't start. It doesn't even crank/fire. Radio, windows, wipers etc.. all work. I did notice when i put the key in and turn it forward but not cranking, none of my dash light icons are on. What could this be?
Old Jun 15, 2006 | 11:33 AM
moparman's Avatar
Re: Ignition switch, Ignition cylinder, or what else?
Did the security light come on?
Old Jun 15, 2006 | 11:37 AM
sean1997ws6's Avatar
pull the PCM Batt. fues on the side of the dash and let it sit for about 5mins until the security light goes out, put it back in and fire away.
Old Jun 15, 2006 | 12:09 PM
Sweetred95ta's Avatar
You got off at a video store?? And it only took 5 minutes?? LOL Anyways, did it pop when you turned the key? Check for the security light like the others said.
Old Jun 15, 2006 | 01:49 PM
fast96lt4's Avatar
No security light. No lights are lighted at all on dash.
Old Jun 15, 2006 | 03:22 PM
May sound too simple but did you check all your other fuses?
Old Jun 15, 2006 | 03:25 PM
If your headlights still work brightly, it's probably the ignition switch or connection to it. Just for a try to see if it can get you home, try flipping the key back and forth from ON to OFF quickly numerous times and see if it might happen to catch. Depending on the state of deterioration of the switch, it might work.
Old Jun 17, 2006 | 09:08 AM
fast96lt4's Avatar
I changed ignition switch, and car still doesn't turn on. When i turn key over, i was seeing sparks coming from the ignition switch But still no dash lights and won't start. What else could i look into? The pigtail? The blue connector had a brown spot but didn't look to severe.
Heathen1
Jan 2, 2016 04:27 PM
blac94Z
Jun 11, 2015 06:17 PM
chevyalltheway
May 24, 2015 04:26 PM
beltrunner
May 17, 2015 10:18 PM
robcarnut
Mar 20, 2015 03:40 PM
