Proper cleaning/polishing for engine parts
I have always preffered to sandblast my engine parts clean. Intake manifolds, somtimes throttle boddies, anything really that can be shined up. I also use a Cuda High-temp engine wash machine after i am done to make sure i get all of the sand out. I have recently heard that sandblasting can be very bad internally for you engine. I find that it smooths out cast aluminum intakes, as well as helps to polish the outside.
The other alternative would be a wire wheel but i have also heard that this can but just as bad. What does everyone think?
Re: Proper cleaning/polishing for engine parts
My personal secret at getting the manifold shiney, or any alumimum part for that matter is take a brass cup wire wheel and put it on a 4 inch grinder and lightly hit all the surfaces. DO NOT do this on any gasket or seal surface. you can take some smaller rotary brushes and get the hard to reach spots. But on the LT1 intake if you do this by the time you get everything back on it will be shiney like new. Be advised this is somewaht dangerous so wear some protective gear like eye protection and heavy clothes. I usually wear welding gloves and a jacket when i do this. Learned this from a hotrodder that restored old parts and did not or could not have them blasted.
Looking for opinions here as i am a little less than educated on the subject myself.
I would not be wary of sandblasting parts as long as you are 100 percent sure the media is gone afterwards. I can't be sure so I stick to the hard way-by hand.
Gradually go finer on the sandpaper and then use some Mothers. I usually do the final wetsand with 1500 grit paper and then use the Mothers. Looks awesome but takes time.
oldschool
Feb 9, 2016 09:21 PM
