What you think it should run?
Old Sep 29, 2004 | 06:32 AM
Meen95z's Avatar
I have a 95 Z28 with LT1 or course. I wanted opinions on what it should run at the track. I have (Moroso CIA, GMS MAS, MSD 6A, MSD Blaster Coil, MSD 8.5mm Super Conductors, Hypertech Power Programmer 3, hollow cat, American Thunder Cat back, TPIS airfoil, 3000 TCI stall, slp air temp sim, Pierson lower control arms, 3.42 gear, Kenny Brown Subframe Connectors)? Opinions Appreciated thanks
Old Sep 29, 2004 | 09:48 AM
blackztpi's Avatar
Re: What you think it should run?
well, first of all. replace that coil with an accel. msd coils suck ***** for lt1s. mine was new and it hit the ****ter and many other people have had the same problems. but I'm no expert, nor do i know what hpp3 is, but probably low 13's with reasonably traction. expect traps to be from 102-105 i'd say. ??
Old Sep 29, 2004 | 09:49 AM
blackztpi's Avatar
mid-low 13's meaning 13.2-13.4's with good traction.
Old Sep 29, 2004 | 10:33 AM
CColtManM's Avatar
On street tires, which i am assuming you are using because you don't have it otherwise noted, 13.4-13.7.
Iamherefornow
Jan 26, 2015 04:57 PM
Amshnock
14
Jan 18, 2015 11:47 AM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
dirtybird81
10
Jan 6, 2015 09:31 PM
