About to install brand new lifters, quick question...
Old Sep 30, 2004 | 06:04 PM
texasTA's Avatar
I am about to install brand new Comp R lifters in my 1995 Formula that we are doing a cc306 cam install on.
What are the preperation for these lifters? Aren't you suppose to soak them in oil to completely coat the inside of the lifter? If we aren't goign to be able to install them until tomorrow afternoon, should we place all the brand new lifters in a pan with fresh oil to let them soak over night?
Matt
Oh, and what other valvetrain parts need to be soaked in oil before installation?
Old Sep 30, 2004 | 06:50 PM
cmking26's Avatar
Re: About to install brand new lifters, quick question...
I soaked my lifters overnight. I used assembly lube on ends of pushrods but thats it for valvetrain.
Old Sep 30, 2004 | 10:30 PM
Don 97 SS's Avatar
Comp has very informative tech info on their website. The lifters come with a protective coating that needs to be cleaned off. The lifters should then be lubed either by soaking or by simply squirting oil in the side oil hole while holding them upright. Use assembly lube on the rod tips at the rockers. I've seen various other procedures such as pouring oil over the entire valve train so that any parts subject to friction is not "dry". Everyone seems to have a certain method that basically achieves the purpose. I think it is very important to pre-lube the engine prior to start-up.
Old Oct 1, 2004 | 01:01 AM
Z95m6's Avatar
I believe my Comp R's said to soak them in oil for 30mins.
Old Oct 1, 2004 | 03:16 AM
disco192's Avatar
I always soak lifters overnight and periodically shake the pan so it can get in all the crevices and gets all the bubbles out.
Have setting the lash on those.. they are a biach. I HIGHLY recomend setting lash with the engine running.
chevy95z28
Jun 22, 2015 09:28 PM
alliance12364
Mar 6, 2015 04:39 PM
Jan 23, 2015 01:13 PM
97TA-WS6-Con
Jan 10, 2015 05:31 PM
Catmaigne
Dec 25, 2014 12:16 PM
