What Valve Covers To Use With Afr 227 Lt4 Heads??
Old Oct 1, 2004 | 11:38 AM
fast 93 z's Avatar
What is a good cover that is tall and will clearance the outer rockers and also clearance the alternator? The heads are drilled for center bolt and perimeter bolt valve covers. The stock LT1 covers are not tall enough....the Melrose T-top aluminum dont clear the outer rockers (cc pro mag 1.6 7/16). What can I do?
Tony
Old Oct 1, 2004 | 12:05 PM
kmook's Avatar
Advanced Tech Moderator
Re: What Valve Covers To Use With Afr 227 Lt4 Heads??
http://web.camaross.com/forums/showthread.php?t=161082 look at what brand-x has to say.
Also i removed the other thread as this should be discussed here. FYI, thanks.
Old Oct 1, 2004 | 12:43 PM
fast 93 z's Avatar
Thank you!!
Anyone else?
Old Oct 1, 2004 | 02:31 PM
Bastardcat's Avatar
You can have RFR Custom Metal Fabrication build you a set like they did for me as seen here.
Old Oct 28, 2004 | 12:46 PM
Jim S. '95 Z28's Avatar
How much did those set you back? I'm assuming you provided the measurements to them?
Old Oct 28, 2004 | 12:51 PM
Bastardcat's Avatar
I think the total for what I got was at $360. I did provide the measurements--but I believe he still has those and should be able to build a set from those.
Old Oct 28, 2004 | 01:13 PM
simple's Avatar
those are pretty!
Old Oct 29, 2004 | 10:11 AM
LT4383's Avatar
RFR fabrications does have all the measurements still. The CNC shop is a month out on orders, so be ready to wait. Very nice covers and worth the wait for me!!
LeftoverChinese
Jan 14, 2024 03:03 PM
MadMav
Feb 6, 2015 11:02 PM
Jazsun
Dec 29, 2014 12:14 PM
