Comp R or not? LE2 package
Old Sep 27, 2004 | 03:44 PM
97s10ondubs's Avatar
I was wanting to get some stock lifters because of all the problems I see people having adjusting the Comp R lifters, but will a new set of stock lifters hold up?
Old Sep 27, 2004 | 03:47 PM
ibanez6rg's Avatar
Re: Comp R or not? LE2 package
Comp R's here, no problems.
Old Sep 27, 2004 | 08:55 PM
will stock lifters hold up though to the le2 cam?
Old Sep 27, 2004 | 09:15 PM
ibanez6rg's Avatar
Should, dunno what your plans are with your car.
Old Sep 28, 2004 | 11:11 AM
TransAmGT94's Avatar
R lifters are the way to go ive got a set that im going to put in when i get the rest of the parts together to rebuild it all. Im sure there have been just as many problems with the stock lifters as the R lifters.
Old Sep 28, 2004 | 11:14 AM
WS Sick's Avatar
Depends really onyour spring pressures, if its over 350 #s open then it will be questionable.
Old Sep 28, 2004 | 11:31 AM
atljar's Avatar
Maybe if you knew the cam/spring specs we would help you with supporting components, but since you dont.... Call Joe, call lloyd.
Old Sep 28, 2004 | 12:47 PM
SAR2K's Avatar
Stock lifter can take much more abuse than folks think. We're running stock lifters on Jason99TA's set up. Cam is 244/254 .632/.628, not a daily driver, but you get the idea.
Steve...
Old Sep 28, 2004 | 01:31 PM
SStrokerAce's Avatar
It has more to do with spring loads and RPM more than anything.
The LE2 package can work with out them but it will work better with them. If you are running a spring like a 977 then it's a good idea since that's a beefy spring.
Bret
13qtr
Oct 28, 2016 08:11 PM
football4life
Oct 4, 2015 07:48 AM
sh0ckl3y_z28
Oct 3, 2015 06:34 PM
9t4lt4z28
Oct 2, 2015 10:28 AM
Z Power
Sep 19, 2015 11:19 PM
