Programmed out KR but still get KR...
Old Sep 27, 2004 | 03:56 PM
turbo_Z's Avatar
Question Programmed out KR but still get KR...
I can't seem to figure this problem out. I have totally "0" out all KR in every table but I still get KR. The only problem area is right off idle. Sometimes the computer will pull 6 degrees right off idle as I let out the clutch which causes the motor to stall out for a split second. Ill watch my scanmaster and every single time I get going w/o problems theres no KR and every time I stall it theres 6 degrees flashed on the scanner so I am 100% sure the KR is the source of this stalling problem. What I cant understand is how this is even possible!? If you cant program out the KR then how the hell do you get rid of it?
Old Sep 27, 2004 | 05:29 PM
Re: Programmed out KR but still get KR...
Maybe you should give details about "every table". Perhaps some expert can tell you one you might have missed.
Old Sep 27, 2004 | 06:00 PM
turbo_Z's Avatar
As in any table with the work KR in the name.... this is tunercat too.
Old Sep 28, 2004 | 11:25 PM
turbo_Z's Avatar
Anybody else have this problem?
Old Sep 30, 2004 | 10:48 PM
turbo_Z's Avatar
My last try.
revrider
Cars Wanted
Apr 5, 2016 10:06 AM
MDZ28
11
Sep 24, 2015 09:15 AM
marlar98
Sep 19, 2015 07:53 AM
FredM
Aug 14, 2015 01:49 PM
whitehooptie
Aug 10, 2015 07:02 AM
