header gasket ?
Re: header gasket ?
It should be the same gasket. Summit has a lot of them in their magazine to choose from, you could probably find them online. All the ones you can use usually say something to do with LT1 or D shaped ports- it's basically the same as the SBC in that respect except the D shaped ports
I just installed Felpro #1406 on my Z last night. Very nice and easy with these gaskets cause they have hooks on the ends of the gasket instead of holes that go around the outer header bolts which allowed me to keep the headers bolted loosly on the ends and slide the gasket in..
Re: header gasket ?
Originally Posted by hawk232
one of my gaskets is leaking and i need to replace it. where would i get replacement gaskets? are they the same as manifold gaskets?
If you have aftermarket headers, you probably should use the Felpro 1406, and if you're still using the stock manifolds, just get stock replacement I guess.
94Z28LS1toLT1
Apr 7, 2015 05:37 AM
