Max lift comp cams 941 spring?
Old Sep 28, 2004 | 09:44 PM
$hawn's Avatar
Anyone know the max lift of the comp cam's 941 valve spring, on there site it shows to be .500 but i'v heard of people running well over that. I have all the specs of the spring but the max lift.
Old Sep 28, 2004 | 09:59 PM
Frank95z's Avatar
Re: Max lift comp cams 941 spring?
I run then with my Crane cam with a bit over 550 lift. On stock valves they set up at about 1.75 and coil bind is 1.13 thats .620 worth of travel with .050 margin that gives you good to 570 lift. Thats just my 2 cents. Frank95
Old Sep 29, 2004 | 10:35 PM
$hawn's Avatar
Hell I didnt know you just subtract the coil bind height from the installed height, and add in your safety margin, thought there was more to it than that. Thanks.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
oldschool
Feb 9, 2016 09:21 PM
MadMav
May 25, 2015 09:35 PM
Cam's maro
Jan 30, 2015 09:21 PM
