How fast can i go with this?
Old Sep 29, 2004 | 04:11 PM
Baby Bird's Avatar
I have a lil idea goin in my head and was wondering how fast i could go with this.
383-eagle 4340 crank and rods, JE pistons, good bearings and the other good lil stuff.
LE3 package. Or LE2 heads with a custom cam??
vigilante 3600-3800 stall.
12 bolt or 9" with 3.73 gears.
Hooker long tube coated headers and y-pipe and hooker catback.
52 or 58 mm throttle body bigger injectors etc.
4L60E rebuilt, or a th-400 if io cant get a 4L60 to hold up.
ALOT of nitrous. How much could this setup hold? Dual stage 300, 200+100??? Or more????
I know ill need a cage and a bunch of other small stuff but im prepared for that, but i wanan start getting my combination together and see how fast i could go with what i have in my head right now. This would be a daily driver, that id want to run deep in the 10s on spray.
Old Sep 29, 2004 | 11:22 PM
1 Nasty Bird's Avatar
Re: How fast can i go with this?
Sounds like a fun plan, i wanted an 11 sec daily driver on spray. Im sure if you can get it to hold enough spray you can go 10s and be daily drivable off the gun.
how about a 600 shot 300+300
Old Sep 29, 2004 | 11:48 PM
chrism400's Avatar
Better think about suspention and tires to go that fast.
Old Sep 30, 2004 | 06:11 AM
TQdrivenws6's Avatar
If you want to run a big shot of nitrous, go with a 5.7 rod and some heavier compression height pistons. On the motor with good suspension, mid to low 11s would seem reasonable if you can launch it hard enough.
Novo
Jun 14, 2016 02:58 AM
Jeff1904
Jun 5, 2016 05:00 PM
football4life
Oct 4, 2015 07:48 AM
Matt Dreessen
Sep 9, 2015 09:58 PM
damnyankee36
Sep 9, 2015 07:06 PM
