Possible metal in engine, got to bearings
Old Sep 27, 2004 | 04:27 PM
OnefstCamaroZ28's Avatar
Banned FOR SCAMMING - Nick[William] Dascal - (516) 931-0586
Alright, I recently did a Cam/Head swap, Comp Cam 305, Custom Heads. I also did a intake manifold that was bored out to 58mm intake, what i failed to realize that there was metal shavings still in the manifold when i put it on my car. I thought it would blow right out, but it didnt, i dont think. My engine is running terrible, but i only went about 30 miles since the cam swap. So maybe its still breaking in. Im not sure. But I took the dipstick out today and my oil had a grey tint to it, like bearing residue, could that be it?
Does anyone know how much it would cost to change the short block or the bearings?
Old Sep 27, 2004 | 09:03 PM
Josh-'04 GTO's Avatar
Re: Possible metal in engine, got to bearings
Are you serious? The short block is likely junk, depending how many shavings got into the engine and how much damage they did.
Costs to rebuild the shortblock will depend on the time and materials used.
Old Sep 27, 2004 | 09:11 PM
This sucks, how do you really find out if that short block is crap
Old Sep 27, 2004 | 09:47 PM
5.7LT1Formula's Avatar
"what i failed to realize that there was metal shavings still in the manifold when i put it on my car . I thought it would blow right out....(or suck them in!), but it didnt"
sounds like bad news bears for OnefstCamaroZ28
..you can drive it for awhile..but major wear is happening to your motor...only way to get ALL of it out is to hot tank your block and start over..i would keep your oil/filter changed and put a magnet in you pan and get a drain plug w/ a chip collector..
Old Sep 27, 2004 | 09:54 PM
This is horrible, what does it USUALLY cost to replace the bearings, or pull the engine, and hot tank it and reassemble it with new bearings....
Old Sep 27, 2004 | 10:57 PM
if you can pull the motor yourself and take everything apart so it is a bare block and have a good machine shop hot tank it...and replace rings, seals, freeze plugs, bearings, gaskets..your looking at least $1000.00??
i had 450.00 in .030 bore w/ tork plate, hottank, freeze plugs, magnaflux and cam bearings..
i have around 3k in mine and its not in the car yet..but darn close...mine is built alot more than stock... it maybe worth yourwhile finding a diff. motor for 700ish out of a wrecked car and just dropping it in..keeping your other for parts..just depends how many metal shavings got in there..
Old Sep 28, 2004 | 07:19 AM
kostya_f's Avatar
If I were you I'd change the oil before going anywhere. It will not save your motor but may keep it running for a few more weeks.
Sergio
Jan 27, 2016 04:27 PM
94Z28LS1toLT1
Parts Wanted
Jan 21, 2015 04:37 PM
1996LT1Z28
Dec 1, 2014 01:01 AM
Jul 4, 2005 05:00 PM
