holeshot w/ nitto's
Old Sep 29, 2004 | 11:02 PM
mojorisin's Avatar
holeshot w/ nitto's
im about to get nitto dr's, and i was wanting to know if anyone had sprayed off the line with them...if so, what kind of 60' should i expect? are these going to hook hard enough to break my stock rearend w/ fresh 3.73's and a 2500 stall?
Old Sep 30, 2004 | 12:43 AM
'94 Bad A Z28's Avatar
Re: holeshot w/ nitto's
I always spray off the line.... I was pulling 1.7xx short times before my tranny went. But that's all fixed now.
Old Sep 30, 2004 | 12:44 AM
Oh yeah.... stock rear with 3.73's T/A Girdle and a Yank 2800 stall converter.
Old Sep 30, 2004 | 11:59 AM
"White Knight"'s Avatar
I have trouble hooking what i have right now......60' in sig. That is with a little wheel spin. Do you have suspension mods? I plan on getting some LCA and brakets and drop that 60' to a 1.6XX. You won't be able to spray directly out of the hole---you are going to have to wait to get above 20mph probably, because i spin my nittos at 15 on the street. So taking into acount it's a track and preped.......you will get a little better traction, but then you will be spraying probably 100+shot......I would think it would be higher than what i can spin them on the street....so probably around 25-30mph would be a good time to spray
Old Sep 30, 2004 | 12:02 PM
As for breaking your rear-end--I highly doubt it, expecially if you use a solid pinion spacer. These things just don't get the bit needed to break an automatic trans car's rear-end----to much give in the tranny and converter. You'd be fine.
RUENUF
Mar 13, 2016 03:37 PM
HibachiZ28
Nov 6, 2015 12:53 AM
mrwz28
Jul 8, 2015 09:11 PM
sloppytot
Feb 25, 2015 08:30 PM
