How luch more would longtubes and x-pipe give me?
Old Oct 1, 2004 | 05:19 PM
wicked_95z's Avatar
Ive got a 383 with the works minus a good exhaust. I knew my exhaust was hurting me so last night I unbolted the cat-back and ran open from the y-pipe. My times drop a 1/2 second on avg and I gained about 5-6 mph. I'm currently running a 13.2-13.3 with a 2.4-2.5 60' with a stock 10 bolt,posi on the way out and a mail order tune. Even with all of this against me how much could I look forward to gaining with the above mentioned exhaust change.
Old Oct 1, 2004 | 05:36 PM
teke184's Avatar
Re: How luch more would longtubes and x-pipe give me?
a HALF second! from just unbolting the exhaust!!
what kind is it? stock???
on a 383 i would say true duals would probably pick up 10hp peak, and probably similar all the way trough the rpm band. maybe a little less gains in torque down low.
Old Oct 1, 2004 | 05:42 PM
Ryan94ZA4's Avatar
It's been said that until you are over 750 hp that long tubes aren't as good as a good midlength or shorty header. You lose low end and the midrange is not much different.
Correct me if I'm wrong.
Ryan
Old Oct 1, 2004 | 06:10 PM
bdc95ta's Avatar
it's the primary diameter that really effects the low end torque. The longer piping on a 4 to 1 header actually helps the low end!
-b
Old Oct 1, 2004 | 09:53 PM
Haskin Z28's Avatar
longer primaries resonate at lower rpms..LTs defintaley make more low rpm power
Old Oct 1, 2004 | 11:27 PM
Kreinmc's Avatar
Ryan
Your wrong!
Old Oct 2, 2004 | 01:29 AM
bdc95ta's Avatar
check these out for info:
http://www.houston-f-body.org/tech/exhaust/exhaust.htm
http://www.burnsstainless.com/TechAr...harticles.html
those should get you started
-brandon
Old Oct 2, 2004 | 07:50 AM
wicked_95z's Avatar
Right now i have 1 5/8 edelbrock shorties into a 3 inch y-pipe. And I was running a 13.7 avg. the week before ( I did manage one 13.5 pass) and last thursday I ran 13.2 and 13.3 spinning through 2nd and managed another 13.5 pass but that was cause i missed third
Old Oct 2, 2004 | 09:20 AM
AvrilLaPete's Avatar
you're only pushing 13.2??? With a 383? Is their something wrong with your car? I have a regular non-stroker and I'm pushing low 12s.... Just curious as to what building that stroker is actually doing for ya.
Old Oct 2, 2004 | 09:25 AM
Kyle@CSS's Avatar
Exhaust would be nice. But I bet you would pick up more with a set of ET streets. 2.4-2.5. Spinning looks cool. But its really not. Theres no reason to put more power to it if you can't hook.
Old Oct 2, 2004 | 11:03 AM
dmoor88's Avatar
Ryan
this is completely false. mids have a slight upper hand on long tubes, but only AFTER ~6500 RPM's. Even in that case is only a few hp. long tubes make the most power across the board. this has been proven again and again.
Old Oct 2, 2004 | 03:22 PM
wicked_95z's Avatar
Well like I said I have a stock 10-bolt with 150,000 miles on it and a posi that is on its way out the door. I do have slicks but if I do the math; 1 pair of slicks + 1 stock 10 bolt + 1 street twin clutch= either me stalling at the line or bye bye 10 bolt. And I dont have enough money for the 9 inch yet. Im not one of those guys who likes to spin at the track I just dont have choice in the matter if I dont want my car sitting in the driveway collecting dust again
Old Oct 2, 2004 | 04:08 PM
ABA383's Avatar
Just my .02, but I wouldn't do a thing until you got your rear end and suspension squared away and are able to put your power to the street/track...Really doesn't matter what headers you get if you can't harness the power now...
--Alan
marlar98
Sep 12, 2018 07:18 AM
generaldave
Sep 25, 2015 06:48 PM
tdigger9899
Sep 7, 2015 10:56 AM
97SSdude
Aug 21, 2015 09:36 AM
jbc3
Jul 28, 2015 12:24 PM
