Anyone with the LS1 brake upgrade. Any ABS problems?
Old Sep 27, 2004 | 11:04 PM
madwolf's Avatar
I have upgraded to LS1 brakes recently and now I am getting an ABS INOP light. I know of another person with a 93 who also has the same problem.
Here is what happens.... As long as the car is not moving, there will be no ABS light. As soon as I start moving, the LOW TRAC light flashes once and soon after that, I get an ABS INOP light. This is while driving, not while trying to brake. So I think it is not getting a valid reading from the wheel speed sensors.
Now, my LOW TRAC light has been doing that before, so I doubt it is related to my problem. I can tell my ABS is really not working because the brakes are locking under hard braking.
I have checked the parts manuals and noticed that TCS equipped cars had a different wheel sensor part number. Could my problem be that the knuckles/spindles came off a TCS car? If so, what are my options?
Thanks!
Old Sep 28, 2004 | 06:02 AM
rlax31's Avatar
Re: Anyone with the LS1 brake upgrade. Any ABS problems?
try cleaning the connections at the wheel sensors first, they may just be dirty and getting a bad connection
Old Sep 28, 2004 | 06:23 AM
Doug 97SS's Avatar
I upgraded to Z06 brakes and I have no ABS problems. I did make sure my connectors were clean etc before I reconnected everything.
Old Sep 28, 2004 | 07:39 AM
Thanks!
Not sure where you are seeing that. The parts book shows the same front hub for 93-02 everywhere I looked. The sensor is part of the hub. Don't think that is your problem.
Old Sep 28, 2004 | 01:09 PM
madwolf's Avatar
You're right, shoebox. I was looking at the wrong part number. (the sensor in the differential)
I re-bled the brakes today and they brake very well, but the ABS light is still there and they keep locking on harder braking.
I will check the connectors but I doubt that's the problem. Do you guys think that maybe my ABS unit needs to be recycled? I did not have an ABS light before I did this swap so I didn't think that part was necessary.
Unfortunately, I do not have a Tech 2 so if I can't figure this out, I'll have to take it to the dealership to have the code read...
Thanks.
Old Sep 28, 2004 | 02:20 PM
rlax31's Avatar
Thanks.
Of all the people on this board who would have one, I'm suprised you don't
Old Nov 1, 2004 | 07:04 PM
madwolf's Avatar
For anyone who was curious about this, I just fixed it.
The ABS INOP light got really old and so did the brakes locking all the time.
I decided to swap my old rusty 93 hubs in place of the LS1 ones. (which look brand new BTW)
I pulled out the wheel, caliper and disc, then removed the hub. I decided to examine it before putting the old one in. Well guess what... one of the connector pins inside it was bent. I'm surprised I haven't noticed that before... I looked 3 times with the wheel on.
As soon as I put everything back together and reset the ABS module - NO MORE LIGHT!!! Yes!!! Brakes work perfect now.
jj_burchiel
Mar 21, 2015 12:51 AM
dluna333
15
Mar 13, 2015 12:30 PM
squarehead
Jan 15, 2015 07:02 PM
ddr698
Jan 9, 2015 10:05 AM
Jazsun
Dec 29, 2014 12:14 PM
