what can be wrong
Old Sep 29, 2004 | 05:58 PM
ollie-99's Avatar
what can be wrong
after about 30 min of drivin the car will start to backfire
the following have been changed
opti, coil, wires, plugs
Its frustrating the hell out of me
i dont know what 2 do
please gimmie ur suggestion
thanks
oliver
Old Sep 29, 2004 | 06:19 PM
ibanez6rg's Avatar
Re: what can be wrong
Maybe the Opti harness needs changed out.
Old Sep 29, 2004 | 08:28 PM
ollie-99's Avatar
just got it scanned
while it was running messed up
according to the Map the vacum stays the same while @ idle and wot
the reading was 150
and fuel is just being dumped in
any suggestions
Old Sep 29, 2004 | 08:51 PM
blackztpi's Avatar
well, if fuel was being dumped in, then it shouldn't be backfiring. thats usually a result of a lean running condition. mine has slight backfire when it pop in the clutch when revs are above 4k, but it's nothing to worry about. I'm guessing yours has a pretty big backfire? well, i'm not sure that it would help, but try adjusting the TPS and set it up to run slightly leaner. u can use a camaro/firebird haynes manual to tell you what stock volts should be. all u need is a screw driver and a digital volt meter. try that and see what happens
Old Sep 29, 2004 | 10:09 PM
izzyz28's Avatar
Sounds like it's time to try a new MAP sensor. Either the sensor is trashed or one of the wires is open/shorted. You shaould have a 5 volt reference signal on one of the wires, and the others are signal and ground. I bet it's the sensor though.
Aaront810
Aug 29, 2020 09:34 PM
9t4lt4z28
Oct 2, 2015 10:28 AM
fift5
11
Oct 1, 2015 10:31 AM
95craz28
11
Sep 12, 2015 07:47 AM
Aaront810
Sep 11, 2015 11:24 AM
