what size rods/pistons
Old Sep 28, 2004 | 03:32 PM
Seal's Avatar
what size bore/stroke am i looking for to do a 355?
for rods and pistons
thx
oh yah, and whats the diff between press fit and bushed rods?
Old Sep 28, 2004 | 03:54 PM
1racerdude's Avatar
Re: what size rods/pistons
It is a 3.480 stroke x4.030bore=355.11CID.You can use 5.7 or any rod as long as you have matching piston's.
Pressed means the piston pin is a press fit in the rod and doesn't move-- bushed is a floating pin that is not necessary if you aren't making BIG HP.Pressed pins will take you well over 500FWHP.Floating pins are good for less friction and minute HP gains.They are easier to install the piston and sometimes come out(usually a install issue) and tear up the cyl wall unless you run "button's".
Old Sep 28, 2004 | 04:03 PM
Seal's Avatar
ok cool, i'll go with pressed then
Old Sep 28, 2004 | 07:40 PM
5.7LT1Formula's Avatar
stock rods and a .030 over bore is a 355 isnt it??
just get it bored to clean the cyclinders up..find a set of LT1 rods and get them reconditioned w/ new ARP bolts..you will have a pretty decent rod when done.
Old Sep 28, 2004 | 07:45 PM
Seal's Avatar
how much are those stock lt1 rods are gunna hold up? (will it hold 500hp for boost?)
and how much is it to get'em reconditioned, and what do they do?
Old Sep 28, 2004 | 09:24 PM
rskrause's Avatar
Moderator
Aftermarket pistons and rods are usually designed for "floating" wrist pins. That's what you should use. However, if you are asking this question should you be building this yourself? I suggest getting a couple of books and an experienced friend to help you out. No offense and good luck!
Rich
Old Sep 28, 2004 | 10:12 PM
1badasZ's Avatar
whats the benefits of the longer rods? the 6" or the 6.125" if thats the right number
Old Sep 28, 2004 | 10:14 PM
500hp i would go w/ forged...stock reconditioned rods like mine are good for around 450 or alittle more...so i have been told. When they recondition the rods they make sure the both holes are sized correctly and they shot pien(sp) the rods to make sure there is no stress in them..keeps them from cracking and stuff like that..they also press in new rod bolts ARP are some of the best. I would shop around and look for the best price on rods if you are going to go forged...i've seen some 396kits all forged for like $1600.00
Old Sep 28, 2004 | 11:39 PM
Seal's Avatar
i wont be building it myself, a friend of mine doug is gunna be doing most the work
hes the man to know bout LT1s around here
Old Sep 29, 2004 | 01:25 AM
Dexter's Avatar
Here is what you need I'm selling it on ebay Item # 7925031674
Old Sep 29, 2004 | 02:41 AM
Seal's Avatar
what size are these? (cc) what kinda pistons, whats the bore x stroke blah blah
need more info man
Old Sep 29, 2004 | 10:34 PM
Dexter's Avatar
They Are 30 Over Pistons, Trw Pistons, And Stock 5.7 Lenth Rods
Old Sep 30, 2004 | 09:49 PM
Seal's Avatar
dished? flat?
93 RedBird
Nov 15, 2015 08:24 AM
RX Speed Works
Oct 1, 2015 10:19 PM
surreybrad
Sep 29, 2015 09:00 PM
autoxr166
Sep 25, 2015 04:21 PM
Jake Bialke
Sep 24, 2015 11:31 AM
