running 306 cam-beehives or 987s
Old Aug 28, 2005 | 09:20 PM
Jameslt1TA's Avatar
I bought a 306 cam and 987s with retainers and locks but no shims that have 9000 miles on them. The cam looks good but im wondering if i should go with some beehives instead. Im only running the 306 and stock heads while i save up for an le3 kit. Will the 918 beehives be enough for the le3?
What all will i need to switch to 918 beehives. Im not familiar with dif installed height and the 987s installed height was all over the place on the previous motor, so can i just install the 918s, retainers, shims?
Thanks guys
James
Old Aug 29, 2005 | 08:56 PM
Jameslt1TA's Avatar
Re: running 306 cam-beehives or 987s
Nobody?
Old Aug 29, 2005 | 09:32 PM
SStrokerAce's Avatar
A few things...
springs, retainers and locks to start
Then you need shims to get them all equal and to measure that a valve spring micrometer to check and set all your installed heights.Valve Sprin Micrometer
Bret
Old Aug 29, 2005 | 10:29 PM
Jameslt1TA's Avatar
Originally Posted by SStrokerAce
A few things...
Bret
Ya ive got the 987s springs, locks and retainers. Ive got the stock shims...can i use those if the installed height is correct? Should the 987s with 9k miles be enough for a 306 cam? I would really rather let lloyd set up my heads when i go with the le3 so i think ill hold off on the beehives if i can.
Thanks Bret
Old Aug 29, 2005 | 10:49 PM
yeah that would work the best later on....
Bret
Iamherefornow
Jan 26, 2015 04:57 PM
Amshnock
14
Jan 18, 2015 11:47 AM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
dirtybird81
10
Jan 6, 2015 09:31 PM
