SES light on for 10 seconds, then off for 7 seconds, then repeats.....
Old Sep 2, 2005 | 03:25 AM
Kurt Crosbie's Avatar
It just keeps going on 10, then off 7 over and over again. What does this mean? Every once in a while it stays on for a few minutes. But it literally goes on for 10 and off for 7. I timed it like this for 5 minutes.
Old Sep 2, 2005 | 08:08 AM
Re: SES light on for 10 seconds, then off for 7 seconds, then repeats.....
It means get it scanned. It's trying to tell you something, but you are not listening.
Old Sep 2, 2005 | 12:10 PM
Adrenalinejunkie1's Avatar
I think he's listening, he just doesn't speak LT1.
Like shoebox said, get it scanned. If you don't have a scanner, you can take it down to Autozone and they'll do it for you for free. That's what I've been doing for years now because I'm too cheap/broke to buy a scanner.
Old Sep 2, 2005 | 12:20 PM
For some reason, the autozone and advance auto parts scanners do not detect my car when I plug them up. I plug them up, turn the key to the on position and it says that it still needs to be plugged up. Beats me, maybe I need to hotwire the damn thing to the battery.
Old Sep 2, 2005 | 12:36 PM
That's strange; I haven't experienced that before. Maybe check the connections on your data port under the dash; it sounds like the scanner isn't picking anything up.
Old Sep 2, 2005 | 12:37 PM
Another thought- make sure the monkeys at Autozone are using an OBDI scanner. I've seen them try to use OBDII scanners on OBDI cars before.
Old Sep 2, 2005 | 03:42 PM
buzz12586's Avatar
95's have an OBDII port with an OBDI computer. Makes it really gay.
Old Sep 2, 2005 | 04:03 PM
No one at Autozone understands that. They only scan OBD-II, anyway. When they see the OBD-II shaped DLC, they think it is OBD-II, which it is not. Then, when it does not communicate, they will tell you stuff like "your PCM is bad".
Old Sep 2, 2005 | 04:10 PM
Chickashaz28's Avatar
also if it still won't pickup like that, go through the generic obd-I
Old Sep 2, 2005 | 04:20 PM
Drowned's Avatar
Check your cig lighter fuse I had the same problem and the cig lighter fuse was blown... I changed it and the scanner worked.
Old Sep 2, 2005 | 04:53 PM
That's exactly what it is! The cigarette light fuse!
They may use obdII scanners, but they also scan obdI. I have had my computer scanned at auto zone before with the same scanner. I'm pretty sure thats not the first time I've mentioned that.
Old Sep 2, 2005 | 07:02 PM
moparman's Avatar
You need to invest in a scan tool. Here's a link to some refurb units at a good price: www.autocheckup.net/
Old Sep 3, 2005 | 01:42 AM
Wickman's Avatar
Would a 95 Z28 need the 12 pin or 16 pin adapter?
Gtpguy
Jan 26, 2015 04:50 PM
97z28k&N
Jan 9, 2015 04:58 AM
sleeperZ96BT
Jun 5, 2005 09:33 PM
Rich_z28
Sep 13, 2002 03:35 PM
Z28Wilson
Aug 1, 2002 04:27 PM
