my Camaro Has a Virus....Help...bad miss
Old Aug 29, 2005 | 08:44 PM
1993Fast_Z's Avatar
i was driving the other day, and i decided to rip into it, i stepped on it, and i heard my worst nightmare....its an Automatic, so when i stepped on it, it downshifted, and then it had a Miss so bad, it sounded like someone pulled 2 wires...i left off, and stepped back on it, and it didnt do it again...is this the Distributor? could it be the Fuel Pump? just replaced Wires...maybe O2 Sensor?
Old Aug 30, 2005 | 05:35 AM
slopokrodrigez's Avatar
Re: my Camaro Has a Virus....Help...bad miss
Go grab the battery and try to rock it back and forth from front to back. Now that you found the battery tray/ overflow resevoir is broke, go down to the chevy dealer and get another one. PN 10402687. $22.16 from GMPARTSDIRECT.COM (I have yet to see an F-body that isn't broke) More than likely the bolt holding it down will break off so be prepared for that. Get one while you're at the chevy dealer.
Once that's done, you can jump on it and not short 12V to ground.
Dave
Old Aug 30, 2005 | 07:48 PM
1993Fast_Z's Avatar
that would explain why my Low Coolant light is on....
Old Aug 31, 2005 | 04:59 AM
Not necessarily. When the resevoir breaks, it doesn't usually leak. While it's cold, open the radiator cap and see if it's full. If so and your light is on. Replace the coolant sensor. They go bad quite often.
If it turns out you have a problem maintaining coolant level, you may have a more serious problem.
Old Sep 2, 2005 | 10:30 PM
1993Fast_Z's Avatar
how could this resevior being cracked cause my engine to have a bad miss
Collector Car
Jan 5, 2015 10:58 AM
fpete1992
Dec 11, 2014 03:51 PM
Snoman73
Nov 17, 2014 07:22 PM
sleeperZ96BT
Jun 5, 2005 09:33 PM
