Electric waterpump freeze plug?
Old Sep 2, 2005 | 01:22 PM
hambone3441's Avatar
Rtv plug or no???
Rtv the actual electric waterpump seal?
Thanks.
Rob
Old Sep 2, 2005 | 01:27 PM
Deenasty's Avatar
Re: Electric waterpump freeze plug?
im thinking you already have the timing cover off, cause if its not, there is no way your going to be able to install the freeze plug. After you press the plug in, either RTV or JB Weld the rear of the plug and timing cover. Thats what I did, and there is no leakage at all...
Old Sep 2, 2005 | 01:28 PM
No I am talking about the freeze plug that is installed in the waterpump housing.
Old Sep 2, 2005 | 01:48 PM
Hawk's Avatar
I put a bead of RTV around it to be safe.
Brian
Old Sep 4, 2005 | 01:24 PM
96trans am's Avatar
What are you guys using for the freeze plug?
Old Sep 4, 2005 | 02:01 PM
The one supplied with the pump.
Old Sep 4, 2005 | 02:13 PM
96trans am's Avatar
I bought it off a guy on here. I bought the Meziere, the only thing supplied was the waterpump not any freeze plugs.
Old Sep 4, 2005 | 02:15 PM
hmm, might ask around here then someone may know the size needed.
Sergio
Jan 27, 2016 04:27 PM
BLK1997Z28
May 7, 2015 03:01 PM
Dan_the_ManZ28
Feb 21, 2015 02:01 PM
IgorT.455/406
Feb 1, 2005 06:18 AM
