Replaced valve stem seals - still smoke?
Old Aug 28, 2005 | 09:13 PM
Jazsun's Avatar
UPDATE #2 : Ok guys I tested today at WOT and it doesnt smoke at all on the intial punch or anything. Just when the engine reaches normal operating temps, your turn it off and come back within 10-30 minutes (if engine has sat long enough to cool off then itll start fine. But if its still hot like above 160 degrees then you will get a puff on startup. HELP ME!
Okay I spent a week raplcing valve stem seals w/ new felpro ones (I slid them over the seal and used a 1/2" rathchet to tap them down utnil they were flush w/ the guide) I also put new LT4 springs, LT4 retainers, and LT4 locks as well as 1.6 GMPP rockers. I finally get the car done and turn it on ...no smoke from pipes...drive it to gas station 3-5 miles away and fill her up, turn her on...no smoke...Drive it around maby another 5-10 miles and she gets upto around 200 on the temp(normal high) and take her home and wash her w/ soap and I also cleaned the tail pipes...possibly got some water inside. I then turn her on and ...it was dark but Im pretyt sure there was a nice puff of smoke...I then let her sit for like 15-20 minutes more and turn her on...no smoke..then 10 minutes later turn her on...no smoke. I dont understand why it would smoke that one time. Do valve stem seals need to be broken in or what?...I didnt try it at WOT yet to see if it would smoke on the initial punch(I would get a small puff right when I punched it but not a continous stream) ...Does it seems like I have bad ring? Seals not broken in? My car also has a small oil seapage I noticed by the balancer..not sure where its coming from but its nothing major but would a bad intake gasket cause smoke like this?
Old Aug 28, 2005 | 09:23 PM
Jameslt1TA's Avatar
Re: Replaced valve stem seals - still smoke?
maybe you got a lot of water in there i dunno. If it doesn't smoke now, i wouldnt worry about it. Oh and when installing the seals you should use some vasiline, makes em slide right on.
Old Aug 28, 2005 | 09:40 PM
Jazsun's Avatar
I did oil up the stems and even used this special tool to slide the seals on which came w/ my seals(didnt know until I did half already). I hope it was the water but that seems kinda odd. Why do you say to not worry about it?
Old Aug 29, 2005 | 09:25 PM
Jazsun's Avatar
BUMP - Check the update at the top of thread.
Old Aug 29, 2005 | 09:36 PM
SStrokerAce's Avatar
Make sure you are postive that they smoke... doesn't sound like you are positive it smokes now. I'm sure the motor has a ton of miles on it and if it only smokes this much I wouldn't worry about it.... hell i've seen 2000 Audis smoke on startup with 60,000 miles of babing them on the clock.
Bret
Old Aug 29, 2005 | 09:46 PM
Jazsun's Avatar
Bret
I know it smokes because I turn it on and run to the back(since there is like 3 second delay until the puff reaches the end of the pipes) The loud tapping noise is odd and doesnt sound good tho, could it be a misfire or something?
Old Aug 30, 2005 | 07:31 PM
Jazsun's Avatar
Old Aug 30, 2005 | 07:37 PM
Robs97Z28's Avatar
did you use the same plastic sleeve, when you put on the seals?
Old Aug 30, 2005 | 07:52 PM
Jameslt1TA's Avatar
I wouldn't worry about it because we have a 85 chevy pu with a 305 and 180,000 miles that smokes alot of blue smoke at all times except idle...just have to ad a quart of oil once a month or more if we drive it alot.
Just check your oil and make sure it doesn't use alot and that is a good indicator. You dont have a serious problem unless it uses quite a bit of oil.
Old Aug 30, 2005 | 07:56 PM
Jazsun's Avatar
For like half of them I was just oiling the valve stem then for the other half (when I discovered the plastic sleeve) I used it. But honestly I cant see why not using it would cause that much fo a difference to create such a puff of smoke, and besides I thought valve stem seals only leaked on cold start not hot?
Old Aug 30, 2005 | 07:58 PM
Jazsun's Avatar
I understand but I just cant stand to see my baby unhealthy it makes me very angry. I just dont know what is causing it. I cant reall see a bad ring being the problem because it doesnt smoke while driving or WOT and has lots of pepe enough to take a 454 73' vette from a dig. The only thing I can think of is this oil sepage around the timing chain/bottom of engine. Cant really tell where coming from. But its nothing major, like it doesnt leave marks on the driveway.
Old Aug 30, 2005 | 08:59 PM
Jameslt1TA's Avatar
Dude, your car is fine you are being paranoid. Oil sepage wont cause any smoke anyways, unless it hits the exhaust. And the extra smoke when you start it up after awhile could just be extra gas setting in the cylinders...dont quote me but it could be. If you really want to be sure, then do a compression check but i wouldn't worry about a little smoke.
Old Aug 30, 2005 | 09:22 PM
Jazsun's Avatar
Ive done compression test! all were around 185-210psi i belive. Actually now that I think of it im not sure if that smoke is blue tint, but i thoguht it was I will check tom. How do you explain he loud *** Tapping noise right when it kicks over too?
Old Aug 30, 2005 | 09:43 PM
Jameslt1TA's Avatar
Maybe the noise is your starter selinoid ingauging? Mine does it or should i say did it...but obviously thats not why it blew up. If it doesn't make any strange noises or smoke at idle, wot, or throughout the rmp range i dont think id be to very worryed about the engine.
Old Aug 30, 2005 | 10:03 PM
Jazsun's Avatar
it isvery loud tap like a rod hitting a peice of metal
HectorM52
Jul 30, 2017 11:46 AM
DirtyDaveW
Mar 15, 2015 07:01 PM
Roadie
Feb 16, 2015 10:34 AM
Jazsun
Dec 29, 2014 12:14 PM
