Car wants to die on cold start
Old Sep 2, 2005 | 08:17 AM
Grims's Avatar
When I converted to OBD1 i devloped some odd cold start issues. First it revs to 1500-2000 RPM, then slowly lowers the RPM. At first this is all it did. Then it started wanting to die when I would take off until the car was warmed up. Now it revs to 1500-2000 RPM then just drops down to 0....and yeh well dies. It will continue doing this unless I keep the RPM up until it is warmed up.
any ideas?
Old Sep 2, 2005 | 07:19 PM
OBE1 95Z28's Avatar
Re: Car wants to die on cold start
Not sure if this causes your issue, but did you change the knock sensor when you did your OBDI conversion?
Old Sep 2, 2005 | 09:33 PM
glfclubhaxsta02's Avatar
Sounds like you have a vacuum leak somewhere!
Old Sep 15, 2005 | 01:29 PM
Grims's Avatar
ttt
actually the high reving happened when I covnerted to OBD1, the car didnt start wantign to die on cold take off until I put on the long tube headers.
Britbilly
Jan 7, 2015 08:49 PM
jayblev95
Dec 1, 2014 06:55 AM
nophix
Nov 30, 2014 10:26 PM
Ricardo
Nov 29, 2014 10:58 AM
USAirman93
Nov 24, 2014 03:37 PM
