Removed my UD pulley, Amps increased
Old Aug 27, 2005 | 05:59 PM
BlackScreaminMachine's Avatar
I had a issue last week with my Alternator not putting out enough power. I had trouble with the car starting. The car would be near 12.5 amps output which is not good.
So I removed it, rather easily and the Amps have improved to 13.0-13.1 amps.
Still a little low, I am going to replace the Alternator. My buddies 02 z28 puts out 14.5 amps. So Its time to replace it. After that I should have all the charging issues solved.
If anything happens, I will replace the battery.
Old Aug 28, 2005 | 11:55 PM
OBE1 95Z28's Avatar
Re: Removed my UD pulley, Amps increased
I assume you mean 12.5 volts, not amps. At idle, voltage output will be dependent on idle speed. A4's idle at around 650 rpm, M6's can idle 800 - 900 rpm. Most auto parts stores will check your charging system for free.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Rde Bandit
Mar 21, 2015 10:17 PM
Jason Short
Jan 19, 2015 06:34 PM
