Ac Issue
Old Aug 30, 2005 | 12:13 AM
96Zm6's Avatar
Ac Issue
When I turn on my ac and drive in stop and go traffic, my temp gets up to the red. I have my fans bypassed to turn on when I turn on my ignition. Also, is my resivoir/drier supposed to be hot when my ac is on? Why is it getting hot? Any replies are appreciated.
Old Aug 30, 2005 | 01:05 AM
mastrdrver's Avatar
Re: Ac Issue
Are you sure your fans are coming on when you turn on the a/c? Does your a/c blow cold or no?
Old Aug 30, 2005 | 01:11 AM
96Zm6's Avatar
Re: Ac Issue
The fans come on when the ignition does. The a/c blows cold but in stop and go traffic, the temp gets up there. With the a/c off it runs fine in stop and go traffic. Thanks for the reply.
Old Sep 2, 2005 | 10:12 PM
Ellis's Avatar
Re: Ac Issue
The dryer should be cold. If you are in a humid climate, it will sweat. Does your AC blow cold all the time?
Sounds like your cooling system is marginally working. If it is on the verge of working/not workig, the additional strain the AC puts on the cooling system might put you over the edge in traffic. Check your coolant level and be sure your pump is circulating fluid.
Also, get down and look under the front of your car at the radiator. I have had debris (most recently an ice bag) get sucked up under my car, partially blocking the radiator, and that would make my car run hot in traffic but would be OK on the freeway.
Old Sep 2, 2005 | 11:00 PM
mastrdrver's Avatar
Re: Ac Issue
Does the a/c blow cold even when the temp goes up? Have you ever had the a/c apart?
MyfateZ28
Oct 5, 2015 12:36 PM
rocknroler69
Apr 29, 2015 10:24 PM
sseeya
Apr 9, 2015 06:38 AM
Alex Barnes
Jan 24, 2015 10:21 PM
David Dorris
Jan 17, 2015 08:10 PM
