Anyone in the Des Moines, iowa area????
i have a 97 Z28 and i am having a hell of a time getting some headers on, i just broke a header bolt off in the head and there is a stripped header bolt on the other side that i cant get off. anyone in the des moines area that could help out???????? im willing to pay to get it done but nobody wants to have anything to do with it.
Re: Anyone in the Des Moines, iowa area????
Didn't you post this before? Didn't anyone give you advice? When you do something like this, it is a matter of doing what is necessary to fix it: kinda like every situation needs to be analyzed and then a decisiion made as to how to do the fix.
I believe my response was to just pull the heads rather than fool around with the heads on the car and while you have the heads off, check to see that the headers fit nicely and need no machining and change the plugs if necessary. Seeing how I can't really see your problem, that is the best advise I can offer.
Many on here can guide you though the process of removing and installing your heads, but most can ony make suggestions regarding how to handle your stripped and broken bolts.
Save yourself some time and aggravation and pull the heads. JMHO
If you can't get at the bolts decent, you'll have to pull the heads. Not too hard, just kinda messy. If you do pull the heads, pull the drains out the bottom of the block. I didn't , thought I drained it out the radiator and when I pulled off the rear bolt on the outside of the head, it shot coolant like "old Faithful". It was everywhere. So then I freak and try to put the bolt back in, try doing something real quick, what usually happens? Yup, dropped the bolt on the ground. I can laugh now, but it wasn't too funny then
[Electronics/Car Audio] NavTool Beta Testers Wanted
navtool.com
Sep 24, 2015 03:30 PM
